97explorer717
Do you think this is good?Sea Doo BRP 1998-2005 GTI GS GTX SPX GTS Rotary Valve Part# 420924502 OEM NEW | eBayIt'll read a little high doing the solder method because the cover will flex some when tightened down. Try very small pieces, do a valve in and a valve out test. I've had a couple covers machined, yes, oring groove and lip only. The last one I had done was too tight and really caused issues damaging stuff. In the end I bought a new valve and a good used cover to fix the issue and finally got my 96' GSX build to start. My experince is subtract .006 to .007 (inches) off the measurement with the valve in and .002 to .003 off with the valve out. A new RV should measure at .024.
I can get a brand new one just shipping sucks. Do you know why it would be scoring like that being loose?
