Well it's already filled with black Grease. Didn't see that pin hole in the bottom of the exhaust. Guess when you fire up a ski on the hose that's completely dry and wonder why there's water in there. New to me exhaust on the way. Old ones getting some J-B weld on it. I'm hitting the lake Thursday! We shall see.Dang you got that hull clean that's fo sho... LOL
My number-one find is leaking from the oil tank Reservoir fittings. Honestly if I wouldn't have cleaned it I wouldn't have known the exhaust had a hole in it. Maybe besides the water. Wasn't much there like a cup so... Do you think J-B Weld a hold on pin hole in the exhaust for a day? Just want to go out and baby the motor back in. Going to run at 32.1. Exhaust will be here Friday.I've cleaned up all the ones I do and it ends up with injection oil or some other crap in there. LOL I do love a clean bilge.good luck on Thursday. I have a couple that will need water testing this week.
I have a soldering iron and solder. I got more expensive silver solder for electronics. That never crossed my mind.Wanna try using a soldering iron to glob some of that metal to cover the pinhole? sounds like it'd work lol.
I got 155 a cylinder. Pretty confident on my rotary valve timing setting. I got a degree wheel years ago this ain't my first go with that. I'm pretty sure it's in my carbs. Don't know where it went wrong though. This is my fourth set over the years I've rebuilt. Seats replace pop off pressure tested. I noticed they were trying to stick when Engine was getting warm. The butterflies were sluggish when I originally took them off. They've been sitting 4 years. I lubed and work them back and forth and they freed up. Thinking the bodies are shot. Bushings and seals at the butterflies are done.I am so sorry you’re having such a bad go with this.
SBT is marginal at best.
I would check compression then if it is ok verify the rotary timing is correct.
If those check out and you have spark it has to be the carbs.
