is this something that happened recently? Have you changed impellers? Is the ski running badly, bogging, surging? Check compression and check the spark plugs. What do the spark plugs look like? What is your top speed?
Lou
its a little bog from both and no grey lines at allIs it a bog from idle during acceleration? Or a bog on the top end of performance? Do you have grey fuel lines?
last summer i blew the motor over the winter i put in a sbt motor it it and just recently got it goingI can think of several things but before we start chasing gremlins
(although IMO the rectifier gremlin is worth the quick check)
(I tend to think rectifier, exhaust leak, maybe rave's, and maybe WRegulator but its not topping out low enough)
suarez, can you backtrack and give a history ?
was it always like this, how long have you had the ski... what have you changed recently, assuming it wasn't doing this before, or has it gradually gotten worse ? was fuel selector cleaned when fuel lines were done ?
a tad easier to diagnose with a 'lil bit of background on the ski.
Did you figure out why the last motor blew?
Did you go through the carbs and fuel system prior to installing the new engine?
took out rave valve cleaned them adjusted carbs to stock settings and new plugs gonna test out tomorrow on the water.. where should all 3 rave valves be set for best performanceyip... knowing what happened would be helpful.
who did the engine install, you, or a 3rd party. ?
tuner's ... refresh my memory.. is the goal around 6800 ?
(i still circle back to rectifier, exhaust leak (seen that before), gummy rave's, and maybe WReg, carb adjusters, slack in throttle cable, timing ?, but just throwing out idea's now)
took it out and performed better i got it up to 6750
IMO, that's good enough... were the raves gummy ? How did the water reg look ?
