Hello, I recently bought a 1997 GSX and have two issues.
One, I have the somewhat common issue with the ski not opening the RAVE valves and topping out at 5000 rpms. It will eventually go full tilt up to 6400 rpms after some cycling of off and full throttle. I've rebuilt the RAVES with new diaphragm and o-rings along with the slotted RAVES and updated housings according to the TSB but I still have the problem. Do I now start fiddling with the red caps? If so, which direction?
Second, I was told the base gasket is pushing out and while the part is cheap, the amount of labor by the shop is not. I am fairly handy and have worked on engines. How difficult is it to change the base gasket. It doesn't look too hard, but the tilt of the engine could be an issue
