Great site, with all the information here I've rebuilt the carbs, replaced all the fuel lines and throttle cable that my buddy broke when he snapped the handle bar. Now the engine runs fine, but I have no bottom end, it plows until it planes, then it goes great. I took the pump off and the clearance from the blades to the wear ring is .229 mm. With the cone shaped housing cover removed, but the impeller still in place, the shaft moves back and forth about 1/4". I'm enclosing a couple pictures of the impeller. Any suggestions on where to check next or if the impeller looks bad would be appreciated. This is my first jet ski....
