Hey JAY... you might want to look into replacing your fuel lines because the stock lines tend to deteriorate and create a sludge like material that clogs your lines... also check your fuel valve because I have had two 96 XP's that had clogged fuel valves and the fuel pump on the carb is not always strong enough to pull fuel through the clogged valve or fuel lines... If you want to replace your fuel line it will cost you about $35, just go to your local auto store and get about 21ft. of 1/4 inch fuel line and about 25 stainless steel hose clamps and start replacing one hose at a time. It sounds like alot of work but is really quite simple. Hope this helps ya...
