SLIMCAT
Hello Forum
Picked up a 96 Xp last weekend. Started and runs in and out of water. While at cruise speed it just suddenly shuts off. I did notice that while at cruise the battery light will come on and off but only at higher RPM. The only way to restart it is to pull the DESS key out and re-install and she will start but maybe only run a few minutes to a few seconds and shut off again. No hesitation just quit.
I will check the water flow out of the ports tomorrow for overheat.
I do not get the audible two beeps and will head to the shack for a buzzer. I will take out the fuel selector switch and check for clogging.
The only other thing that makes sense after reading the posts is maybe the POST for the DESS.
I will check for voltage at idle and RPM.
If you all have any other suggestions i would gladly entertain them.
Brian in Bethlehem, PA
