jrwireman1960
ski was running fine, all of a sudden it will not crank. the solenoid engages but the motor will not turn over. If I remove the plugs the motor turns over fine. Put the plugs back in and the solenoid engages but no motor crank. Disconnected the battery and put the ski on my car battery, same thing the motor will not turn over unless the plugs are removed. Any thoughts, could the starter motor not have enough power with the plugs in? Thanks for any help you can provide.
