hal5778
Hello I have a 2000 GS with the 717 motor and when I put the key on and hit the start button it turns over but when I release the start button it continues to turn over until I remove the key? Also when I pull the bottom 2 fuses under the hood without the key installed the starter seems to engage? Lastly could this problem be causing it to not have any spark to the plugs? Thanks in advance to any imput
Update When I put the key on and insert the bottom fuse the motor starts to turn over without using the start button? Also when I disconnect the wire harness from the bottom of the solenoid the motor stops turning over?
