Good choce !!! Bawaaaheeehaaaa !!For the record i used wintergreen floss.
Colgate.
I did, but it isn't necessary. I pulled the grommets and all on the outside when doing the hull/gelcoat work, made it easy wet sanding, buffing and so forth. A few more feet of clear fuel line was logical when I put it all back together. While I was at it, I sprayed brake cleaner in the ck valves and blew them out.Do you guys normally remove the gray fuel line that are part of the vent circuit?
It is really bad for you and nobody knows what the long term effects are. Better safe than sorry.I actually discovered that if you get enough carb cleaner on your skin it soaks in and you get really buzzed just like drinking whiskey!! Lol jk
I should wear some protective stuff for sure.
2 years for me.I got some wintergreen floss around here somewhere I just know it.
Now if I could only be positive which side the blue mark is on. ....
My Concern would be the crank bearings. Good Luck with it !!
Small world!
I work as a Reliability Manager for a paper mill lol
