Hi all,
I recently became a proud owner of my first x4. I am having a bit of a problem where it rips pretty good but for about the first 20 minutes of riding it gets hung up between 4000 to 5000 RPM (according to the TTO tach I added to make sure it wasn't actually hitting the limiter while cavitating or something). It slowly does it less as the 20 minutes or so of riding takes place. If you nail a wave and get the impeller out of the water a little it will allow it to blow past this limit and as long as you keep it above that rpm it'll keep screaming along. As soon as it breaks through this block it shreds like a raped ape. After those 20 minutes of warming up it pretty much completely goes away. If you let it sit for 15 minutes or so off it will start doing it again until it warms back up.
I am very familiar with carb issues on these (as most of us 787 owners are) so it doesn't have that bog feel that you usually get with that. It feels exactly like a rev limiter. I had the carbs off and made sure everything was good to go and up to spec anyway.
Things I have tried are:
new plugs (BR8ES of course)
trimmed both ends of the wires (anyone ever have to completely replace their wires because of issues?)
checked for AC voltage or too high DC voltage coming to the battery, passed the tests
tried pulling the red wire off the regulator just in case, zero change
150 compression on the money on both cylinders
Some random brainstorms. Has anyone had cavitation from the carbon seal that will stop the motor from hitting the max rpm limiter? I would find it very hard to believe that it is the carbon seal just because the consistency of the RPMs that it is being limited to but I'm reaching for ideas.
The coil appears to be newer, has anyone had this kind of issues with a coil or do they usually just go from spark to no spark?
Going to check the resistance of the pickup coil when I get a chance tomorrow probably, see what that comes in at.
Please throw out any ideas you may have. Thanks guys!
