I’ve been struggling with this issue on my GTX since I’ve got it.
Things I’ve done and checked
Rebuilt carb is OEM OSD parts.
New fuel horses.
Checked and verified pop off.
Checked for leaks in entire fuel system.
Verified no leaking in RAVE valves and they do open.
Verified rectifier is outputting about 13.7 V at 4000 rpm.
Probably some other things I’m forgetting.
Here’s a video to show the issues I’m having -
The issue - The ski will idle great and low rpm react fine. But under 3/4 to full throttle it will sound like it’s bouncing off a lower rev limiter. After like ~ 10 minutes of driving it will get worse where I can only idle if I try to give it gas it will die or if I go slow enough onto gas it will pick up some. I can actually hear it’s running on 1 cylinder then the second will come in and out sometimes. (Sounds like it is running on 2 cylinder’s for the first 10 mins and maybe idle?)
I’ve rebuilt the carbs twice and can’t see how it would be a carb issue at this point…
New fuel horses.
