So I'll start this off by saying the PTO side jug has a compression of 130 and Mag side is sitting at 145. So it will be getting a new top end from full bore this winter. I had the carbs rebuilt (by someone else), replaced the grey fuel lines, and cleaned the rave valves myself. The high speed screws are all the way in and I set the low speeds at 1 turn out. It was so lean that it wouldn't even get on plane. So now I have the low speed screw at almost 3 turns out and it still has a lean bog to it. If I give the primer a couple of pumps before I stab the throttle it takes right off. It seems to run fine on the top end, but I have yet to get any readings from the plugs at WOT. Any ideas? I don't know what size jets are in the carb, I'd have to take them apart. Is 3 turns out excessive? I know it could be the pop off pressure, I don't know what it's set at, but I watched the guy do the pop off test myself. He seems to know what he's doing. He used to race the jetskis in the world finals pro-am runabout 800 open and the expert runabout open (he won the championship a few times). He wrenches on snowmobiles for a professional snowcross team for BRP. Thanks. Hoping I'm overlooking something small and easy...
