if you have a light test, then locate the white wire at the coil, then while motor is cranking, probe the connector. If it lights up, then cut 1/4in off the wires at boots' ends, then try to fire ski up. If the wire doesnt light up, then remove the mag cover, and inspect the "pick-up" coil. A bracket holds it in place, and that, its notorious for them to break.
