Have been fighting a cutting out issue for the past few rides. Any throttle above about 3/4 will result in a bog. I can hold 3/4 throttle and run at about 5600 rpm. It will jump up to 7k on holeshot for a second or so and the level back down. It will also cut out on right turns. All is well in a sweeping right turn but any jerk and it will cut out.
Things I've done:
-PO replaced grey lines. Ive verified they are in the correct positions
-Cleaned Carbs/little filters
-Replaced fuel selector
-Unhooked red rectifier wire with no change in symptoms
-Richened up HS carb adjustment which made things worse
-Cleaned out main fuel filter bowl, filter looks clean
-All tested with full tank of gas so shouldn't be a pickup issue even though thats what it is acting like
Things I've done:
