Travisgg
Hey guys. Seadoo started acting up a little last year 3/4 throttle and up. Usually cuts out and stalls is the symptom. Doing it this year as well.
Runs deadly up to 3/4. Choke doesn't save it when its starts stalling/cutting out. Starts right up again and runs awesome. If you are just ripping circles and cruising slower/mid speed no issues.
Fuel lines all done last year as well as new selector switch. Fuel separator cleaned. Cleaned carbs meticulously this year as well and put in new Mikuni needles and seats just cuz... however....i noticed the diaphragm in one on the carbs actually had a couple little holes worm through it so.... I only had some new WSM diaphragms in stock(from before I learned my lesson to only use mikuni genuine parts) and used them. That's the only non-oem part in the carb. Did I just answer my own question there or should I check anything else? Thanks!
