Just trying to sort out kind of a weird issue I've been having with an XP I've been working on over the season.
I just put a new motor (165PSI in both cylinders) in it with freshly cleaned and rebuilt carbs. Mikuni kit, popoff on both carbs right at 29PSI. LS needles at 1-1/4, HS at 1/4. Replaced all the Tempo lines. No mods of any sort. Still running the oil injection pump, not premix, and I've verified it's working correctly.
Idles great, runs great, tons of fun. Up until you try and run it flat out at 100% throttle. There's tons of power down low, and it'll rev right up and get to 53-54MPH, but it just can't hold top speed. It'll just slowly lose power and keep bogging and bogging until it dies. When restarting, you have to flutter the throttle a bit, but it'll start right back up like nothing happened, and go on its merry way.
I'm still pretty new to these things, so I'm at a bit of a loss as to what might be the issue, as basically everything I've seen says it should be running well. Any thoughts on what I might want to check?
