Jim Chandler
Hi all, i am new to this forum and am now a proud first time ski owner.
Background- i picked up a 95 XP last week for what seems like a steal ($700) the hull is in great shape, hardly a scratch on it, and came with a nice trailer. the ski also came with some upgrades (R&D intake, lager pipe and a couple impellers) which were all a plus. the guy i got it from hadn't used it since around 02. I am in the process of going through the engine and other parts all of which point to very low hours. i pulled the plugs which showed low use and i pulled the cabs apart which where also unbelievably clean.
The Problem- part of the reason for the low price was he couldn't start the thing. he was told that the DESS key needs to be reprogrammed
i picked up a new battery today to start digging around with the electronics. when i put the key on i'm not getting the 2 beeps. and when i press the start button i'm getting a sustained beep that will only go away by disconnecting the battery. this also happens if there is no key on it. i am stuck between whether or not to replace the mpem with a replacement i found on ebay that can accept any key or trying to get it reprogrammed and hope the thing wont forget the key sometime or replace the whole white box because one of the spark plug boots fell off.
any input would be much appreciated
Thanks!
Link to mpem on ebay below:
http://www.ebay.com/itm/200959883286?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Thanks!
