bodine465
Weather in the Pacific NW finally got nice enough to pull the skis (95 XP & 95 HX) out of the garage and prepped to play. Go to put the battery back into the XP and notice the hull has an inch or so of oil in it. Crap! Hose must have started to leak. Will chase it down later. Go to fire off the engine, but just get a "chunk". Damn cheap year old battery! Try to jump it, but still get a "chunk". Figure I'd pull the plugs to release the compression and see how it's turning over. Pull the plugs, hit the starter, and I get two fountains of oil shooting out of the plug holes, covering both machines with oil. WTF????? I can see having a leak outside the engine or an internal leak, but both? What would cause this? Assumine a seal went bad, but an idea which would cause both leaks?
