Busted Grouse
Greetings all,
Thanks to this forum, and no thanks to the dealer, the overheating alarm is fixed. :thumbsup: Turned out to be a bad temperature switch in one engine.
On to the next malfunction. After initially running normally, both engines would start to surge, then bog down. Run up to 6000 rpm, down to 3000, up to 5000, etc. I read here last week that there might be a problem with the fuel selector switch, so yesterday I took it out, and when the surging/bogging began, I switched both tanks to reserve. Ran like a champ, so I repeated the experiment with the same results. Finally, in need of fun, I just ran for 10 minutes on reserve, at which point both engines died out and wouldn't restart, either on the main tank or the reserve. Fortunately, only 30 yards from the launch ramp. Wouldn't start today while on the trailer, either.
Bad tank switch(s)? Junk in the tank(s)? Carbs need cleaning? Or just out of gas...(gauge inoperative as of yet). I didn't see anything in the shop manual about the reserve tank -- is it just a lower point in the main tank? So next weekend, where do you gurus suggest I start? Thanks.
