95 seadoo xp 720 No power not turning over
johnny blaze
Took it out it was running great, got hit by one huge wave now I have no power to anything. any ideas???? oh and all the fuses are good and its a brand new battery.
Check the ground cable to the motor block.. Also check in the ebox for any disconnected wires(pull on each wire lightly). Most likely that will be your problem...
Hey this is my jetski I posted on my buddies account by accident... anyways there is 1 wire that disconnected inside the box but is was a hot wire (positive) and was bouncing around in there anything I could've possibly fried Without blowing a
fuse???
Maybe that's my problem something looks like it definitely fried there. What is that pi
ece called and how much is it
I think that's just my trim module I don't think that should be keeping my ski from getting power but I dont know that's why im here
If its the trim disconnect it and see if it fries up again.
Check the 5 amp fuse to see if its blown.
Jetski is fixed runs great just a corroded slightly broken wire cleaned it up reconnected now it works great. Still fried my vts module. But atleast I can still hit the water
Which wire was broken???
glad you fixed most of it.
