Hello all i recently picked up a two1996 seadoo gsx. I’m having trouble with one of them, i hooked up a new battery and installed either of the keys it cranks and fires up but after shutting off and letting the system power down it does not start back up/ have any power at all, no gauges buttons or nothing. Doing some research through this forum and s few other i have a feeling it might be the mpem. Need some help diagnosing, doesn’t beep or anything, im sure the buzzer is broken due to its age/ common issue i borrowed the ignition relay out of the other ski and it has the same issue starts once the battery is first hooked up but then no power to gauges/ anything. The other one runs fine. Any help would be greatly appreciated since I’m new to the jet ski world. I Did test the ohms on the dess and read around 0 down by the power box connection. Checked all fuses/ power being delivered to the ignition relay in the power box it has power. Any info would help thanks.
