717 idle adjustment
bsocko
I tried to search this but the search is not working correctly. I search "idle" and it tells me nothing found.
I need to adjust the idle up on the engines I am working on. Whoever played with it before has it idling at 1000 rpm in the water. They should be a 1500 rpm for the 717.
Refresh my memory where are the setting to bring these up?
Thanks,
Bryan
Yup... like Seadooya said... it's a "T" handle, on the carb where the throttle cable is attached.
Look for the cable, and you will see it coming off at a 45 degree angle.
