Hi, I really need your advice please.
I am in the process of rebuilding my motor after a supercharger break.
I had to open the engine base to clean out everything.
I removed the head, and i did not make any change to the components ( cam or valve..etc )
Now i am putting everything back in place.
1. I locked down the crankcase to TDC with locking tool.
2. I locked down the cam with the locking tool.
3. Now cam and crank are at the TDC
4. I installed the timing gear on the cam, with the 1503 mark visible.
5. I left the timing bold not tight to be able to move the timing gear a bit from left to right
6. I put back the chain on it and put back the chain tensionner.
7. Now the mark a still visible but not 100% parallel with the case.
By the way here is the picture of the timing before i dissamble the engine, it's look like someone already adjusted the timing before and marked the gear cover with a pen, should i put it back to this place or ... ???
I know i have to put the 1503 mark parallel with the case but is it normal that the line are not 100% straight ?
Also should i try to put them straight before or after the chain tensionner is in place ?
I know it is going to bind the chain that is why i left the chain gear not titghen with the screw..
i hope someone could tell me if i am ok.
Thanks
Thanks
