Picked up my first 4-tec. All of my other doo's are 2 stroke. I think I did ok money wise, fairly good condition boat with a locked up 155. It's a 2006.
I have not even had a chance to inspect the engine myself, but the seller said it locked up. He removed the plugs, jet pump, and tried rotating the engine and it's frozen. Said this happened while driving, and he thinks the timing chain broke. I probably need to remove the engine from the boat to tear it down enough to determine the failure, but assuming the block/rotating assembly exploded, I'm curious which 155s are direct interchange with this. I googled for hours and hours and I couldn't really find what I was looking for, what year to year differences exist, etc. I've seen engines for sale from PWC from 04+, and I've seen reman long blocks on ebay that specify specific years.
Anyone have some insight to help point me in the right direction? I'm thinking probably just buy a long block, although if someone was parting out a complete engine from a running PWC I'd likely consider that as well if it was local.
But I assume there are some year to year differences ? I know on the 2 stroke stuff the magnetos and pickups are different between some years, which make things interesting.
Thanks!
Thanks!
