methodsofmahan
i bought a pair of xps . one would run if i jumped the solenoid i replaced the solenoid but i put the small black wire on the positive and the coil smoked . installed new coil . no spark at the plug . i made sue the small black wire is grounded and making connection i switched the entire grey box from the other xp . still no spark . i tried a test light on the white wire on the coil spinning the motor i don't see anything , it does two short beeps when i press the lanyard on . the center gauge lights up . the engine turns over and the tach moves ever so slightly while its spinning over .both grey boxes look new inside with no blown fuses . I'm testing spark by holding the plug on the head and spinning the engine i even tried using a screwdriver and small air gap zero fire on either ski any help would be GREATLY appreciated . i found the measurements for the grey box internals but mine seems to be different i can't find a red wire with a ring connector end inside either box of mine
