rodl86@hotmail.com
I have just purchased a used 2008 Seadoo 230 wake with the duel 430 hp engines. I have had it only for two days, this is my first seadoo boat, and I did not get a manual. Any advice at all would help. I am having the following troubles.
1) Engine on the Left (port) side will no longer start.
Symptems - will make a click sound but will not turn over.
Here is what happened, I started the boat, (both engines) drove aprox 500ft at 3 thou RPM, then the port engine died, and will no longer start.
NOTE: If I try to start the port engine while the other engine is running, doing so will shut off the starboard engine.....Starboard engine easily starts again no problems...
Other things I noticed
1) I started the boat in 2 1/2 feet of water, then 500ft later the port engine died. My guess is I picked up a rock? Pulled the boat out of the water, inspected the impeller, can't see anything.
2) The Forward - Neutral - Reverse (black handle) is very hard to push or pull. Is this normal? could this be it? or a different issue?
3) Prior to the port engine problem, on the first day in the water I had a hard time finding Neutral so the boat would not start, but starts fine once in the proper location.
Any advice would be great....thanks in advance.
