2013 Gtx155 Cranks…No spark, No fuel
Calladrilling
New here.
2013 GTX-155
Sat for a few years before I got it this year.
Replaced plugs, new cluster (paired at a Seadoo dealer), fresh fuel in tank, new battery.
Took it out for a test run, it ran full speed 55ish mph and 7250 rpm. Ran great for about 10 mins before returning to the dock. Started back up and went back out at idle for a few hundred feet then returned. After the second trip out the ski won’t start now.
Cranks full speed.
Took it back to my shop, fuel pump runs and pumps fuel to the fuel rail.
no spark, no fuel through injectors, no fuses are bad, no faults in dash cluster. I did have a Crank sensor fault but that was when the battery was low after cranking.
Any ideas?
It's not going to start with a crank sensor fault. It shouldn't throw that fault with a low battery. I would ohm test the sensor, should be around 900 ohms. Make sure it's cleared and not active or it won't start.
I will test the sensor with ohm meter tomorrow.
Both local seadoo dealer/service center said that CPS sensor is an uncommon issue but said the code can come up with low voltage.
