Spyder7892
Can someone educated me on the bilge pump that is in the 2010 Challenger 210? It appears to be buried under the starboard exhaust and I was hoping to get some info on it before I remove the exhaust. It was working fine until the last time I went to put it in the water and the pump kicked on while backing the boat down the launch ramp. Once it pumped out all of the water in the bilge (less than half a gallon from the previous evenings rain) it continued to run. I am not sure what type of auto sensing switch it uses but it appears that it is stuck in the on position and the only way I could get it to turn off was to unplug it.
Thanks!
Thanks!
