My ‘06 Sportster (155 -non SC) has an aftermarket tach, readily available on Amazon for PWCs, motorcycles etc. it has to be programmed for pulses per rev. Has anyone done similar with their 155 4TEC and knows what the pulse count setting (1-300) for this rev counter should be? I diddled with it today and ended up with a setting of 21 (IIRC) that sort of seemed reasonable under actual run conditions. But I cannot set it using idle revs because i dont know what it idles at. And an add-on rpm counter/run timer doesn’t yet work because it cannot sense spark pulses due to the coil atop spark plug arrangement on the 4TEC.
