I have a problem starting the right engine. The left engine starts right up.
It started out as an intermittent problem. It would start initially, but later not start while on the lake. It seemed to start when I tapped on the starter relay. I tried shorting across the two red leads. The engine turned over and started easily. I had already ordered a new (black) starter relay and believed that to be the issue.
I installed the new starter relay today. I hit the start push button and nothing happened. Left engine still turns over and starts. Right engine still does not. I shorted across the terminals on the right engine and it turns right over and starts. Could it be another bad relay? Doubt it, but can happen.
I checked every single fuse I could find. I noticed a little corrosion in the 30A fuse so I cleaned connector and added some electrical grease to ensure good connection. Double-checked connections.
I checked the starter switch with an ohm meter. It ohmed out a short when pressed and an open when not pressed.
I tried tracing the relay wires from the connector back, but I have no wiring diagram and don't really want to start cutting apart the wire bundles. Are there any hidden fuses or other components that connect inline between the push button switch on the console and with this starter relay?
Decided to check the wires coming into the top of the relay. I started with the left (good) engine. I disconnected the connector and connected a voltmeter between the two pins. It reads 0V without start button depressed. it reads about 12.5 V with it depressed. No surprise here. I then disconnected the connector on the relay connector on the left engine that does not start. It read about 0 V when disconnected, but was not stable. When the start switch was depressed, it read only .5 Vdc.
Decided I had better double-check the start switch. I swapped the two start switch connectors at the dash. The right switch started the left engine just fine. The left engine switch did not start the right engine switch. Same engine still does not start. So, that rules out the pushbutton switch.
Any other ideas? Please help. I have a 1 week trip that starts in a week. Need the boat!
