travisgiven
Hello,
I purchased a 2005 RXT 215 with 16 hours on it from a friend. It has not been on the water since 2007. I then found the posted information below, which concerns me. I spoke to both dealers within a couple hours of my location and none of the service techs are familiar with this old of a ski.
Can anyone suggest a plan of action to upgrade/fix this ski?
It appears I will need to tell the dealers exactly what I want done and what year parts to change to in order to avoid these problems.
From 2011 post:
Yes; I would be concerned about it. A low hour 2004-2006 RXT is not necessarily a good thing. These year skis had several inherent problems:
1. Ceramic washers in the supercharger clutch; they grenade and spit little pieces of ceramic into the oil pump. They must be changed ASAP.
2. Weak flywheel bolts (fixed in 2006)
3. Poor exhaust valve design. Had hollow shafts, and rust (mainly from sitting, hint, hint) on shafts cause the heads to pop off and destroy the engine. (fixed in very late 2006)
I would mainly be worried about #3 above. I would not own a 2004-2006 215 4-TEC without fixing those 3 items above.
From 2011 post:
