Mainely-French
Any Ideas why I have a fluctuation in RPM's while at around half to 3/4 throttle? The fluctuations are about 1000 RPM's. While this is happening, I go to WOT and it seems to drag a few seconds then gets to top end. Immediately after backing down the speed, it seems to run smoothly for near 30 seconds, then surges again.
I bought it used last year. The washers were replaced and the S/C was rebuilt around 55 hours. It has 75 hours now. I had the wear ring, impeller, and the idler valve replaced (would not idle on it's own) this year and ran fine 3 times out. I just replaced the plugs yesterday but will not be out till next weekend.
Thanks,
Rick.
Thanks,
Rick.
