2005 RXT-215 Impeller Replace
I have a RXT-215 All-Stock Running good, besides fuel level gauge being not corrected but need a Impeller and wear ring some cavitations on hard hole shots, want to replace the Impeller the stock says 13/18 pitch but online says 13/19 but not in a solas brand impeller, will a 13/19 pitch will be to tall.
You can have your stock impeller refurbished by Impros, Skat-Trak or SBT.
If you want aftermarket go by their chart not the pitch since all manufacturers measure pitch differently so you can't go by the numbers.
I have a 05 rxp all stock and put the solas 13/19 on it. It runs really well. Increased take off was unbelievable. Topend stayed the same. I didn't put a stainless wear ring then but have it torn down now to install one. You should be fine with the 13/19.
OK Thanks, Was not sure cause I've seen two different brands and pitch with different prices all come with impeller, wear ring, spline tool and nose cone.
