2004 SEADOO RXP 215 SUPER CHARGED **ISSUES**!!
Seadoorxp2004
Looking to see if anyone can help me out with a problem, lets a friend ride my seadoo and he was spinnin around on it lots. He came back and it wouldn’t go over 25mph usually goes 70mph. Seadoo will start then shut off 10 seconds after. Seems like the machine is bogging and running shitty. Not really sure what it would be this is my first seadoo
2004 seadoo 215 rxp super charged
Runs for 10 seconds or so then bogs out
i ended up draining gas tank, adding oil and changing out spark plugs made the machine run way better. But now at 3/4 throttle the seadoo doesn’t wanna reach top speed. Usually goes 73mph, but will go to 55mph max? Not sure whats going on and rather not pay big money at local dealership. Please if anyone has a good idea why its not running like it should be! Also for example when goinh 45mph the rpms go up and down from 6000-5000 while keeping a steady speed
thanks
Check the impeller and wear ring. If RPMs are varying and speed is not, you could be cavitating.
