jigowattsdiesel
Hi, this is my first post. This is my wife's ski and it started doing this last year. At first it would just shut down only once right from the boat launch when cold after revving up over 3400 rpm's. Now it has gotten much worse. She has to let it idle for about 15 minutes before it will get above 3400 rpm's and run without shutting off. She keeps trying to give is some throttle and it just shuts down with the loud alarm. So she uplugs the key, re installs the key and restarts. The "oil" message shows briefly in the dash while the loud alarm is sounding. She said she saw the maintenance light flashing in groups which I instantly knew was a code. She got it to do it again but didn't count right. I got on the ski and the code would not re-appear or even do it after the alarm. (of course).A couple weeks ago I bought a slightly used <Sea Doo 04 2004 GTX RXT RXP 4-Tec oil separator housing pressure switch shut off> from eBay and put that on the ski last week thinking the oil pressure switch and the shut off valve would hopefully cure this problem. It did not. It has 96 hours on it and I do all the oil changes every year (Castrol GTX 10-40 not synthetic) and K&N filter. I changed the o rings on the filter housing this spring also. Last year I rebuilt the Supercharger myself with the upgraded washers. The other problem is that it sometimes idles really rough and sounds like crap even up to about 3000-4000-rpm's. Then sometimes it runs absolutely perfect. Now, our last outing on the lake, it lacked power, just like a SC that wasn't working. It would only go 40 mph @ about 5500 rpm's. Then I got on it to ride and see what I could. And it did the same thing. So I stopped, pulled the key and scratched my head. When I restarted to begin the trip home to the boat launch, it ran perfectly again. Now at home, I pulled the SC rubber intake hose and could turn the SC with my fingers just barely (with engine off). So I believe the SC is fine. I checked the plugs and they are perfectly uniform and very clean. Gremlins got my wife buggin'! Please help me :willy_nilly:
