2004 GTX 4tec Pcode 1680
06scoob
P1680
Comminication problem detected by MPEM
Ski sat for 1 month, MAYBE, go to start it in the driveway and 4 beeps when i put the key in and displays this code. Any idea what would cause this?
just looking for some ideas on where to start looking
Corrosion can creap up in electrical connections, especially when the ski sits idle.
Same with battery, only its called sulfation. I suggest you go over every electrical
contactor, fuse & holder, plug, and clean then dielectrical grease each one, at a time. You may find a broken or not connected wire. Good luck!
thanks bill, i also looked into it, said possibly a bad 1A fuse, unfortunaly i wont be able to take a look into it until saturday as by the time i get off work its nearly dark!
