Hi everyone,
A few weeks ago I ran my tank very close to empty. After refueling and taking the boat out a different day, there were some issues with it beeping if I idled for any length of time, and a studder / hesitation when raising the throttle just above idle.
The problem slowly got worse to the point that now it stalls / dies as you transition off idle, and beeps constantly. If you get past 2500rpm it will run perfect.
I replaced the fuel filter/water seperator unit (looks like an oil filter with a sensor.)
That didn't make a difference, and the problem has really gotten bad.
Removing the sensor from the fuel filter didn't make a difference
Removing the 12V clip from the small black (fuel pump?) labled:
SAE J1171 MARINE
US PAT. NO 5.
3629674
3797522
4299544
4306842
4464613
FLOW ->
12 VOLT
Completely fixed all issues.
The idle cleaned up, the beeping stopped, hesitation / surging went away, etc...
What is the significants of this 12 Volt fuel pump, and why does it run perfect without it????
SAE J1171 MARINE
US PAT. NO 5.
3629674
3797522
4299544
4306842
4464613
FLOW ->
12 VOLT
