2003 Seadoo GTX DI "MAINT" OUT OF SYNC
JACKOMO
I think my throttle bodies are out of sync on my 03 Seadoo GTX DI as "MAINT' flashes on the dash . I see that the manual says to measure the resistance on the master TPS and add 175 ohms. Then to set the sync screw so the computed value is +/- 20 ohms. Then it says to measure the slave, subtract 175 ohms and adjust sync screw to +/- 20 ohms.
My question is once I set the master to +/- 20 ohms will the slave be thrown off once I play around with the sync screw again??? Not sure if I am missing something
Also once I set this is there a way to reset the "MAINT" on my dash if it is sync'd properly??
Thanks!!
