ok i bought this sea doo from my neighbor he said he tried jump starting it with a battery charger then it had no spark. ski has been sitting for +- 5 years, i replaced the battery old one was shot, could not get power to gauges no beeps, but i had power at the 15 amp on the mpem and in the rear electrical box. there was a 5 amp fuse missing so i put one in on the mpem and it popped immediatly. i found another thread on here that said to try to unplug the stator and put in a new fuse i did that and it did not pop but when i plugged the stator back in it popped again. i proceeded to pull off the flywheel and the stator, this time the stator was not touching anything that went to ground i put a new fuse in and it did not pop as soon as i touched the stator plate to the engine block the fuse popped again. does this mean the the generating coil or trigger coil is bad? any help would be greatly appreciated thank you.
