Greetings fellow watercraftsmen, I purchased this 01 GTX RFI ridiculously cheap with trailer because the PO had removed the engine to replace a starter, then lost interest upon reassembly. As I received it with a new aftermarket starter is installed, and the engine just sitting in hull. So upon getting it home I pulled the engine out a set it on my work bench, my intentions are to clean it up, check compression, replace all hoses, lines, ect and if all check out, drop it back in. Any information on the RFI 787 before putting the motor back in would be greatly appreciated. A couple of question I have are;
The aftermarket starter is a EMS global, Ive been told by others not to mess with aftermarket starters because they just dont last and Ill be pulling the motor again soon to replace it,... is that true ?
The injection rail; Im well versed with Mikuni carbs and have rebuilt several with great success but have no experience with this injection rail, how durable is it ?..... can I just clean it up and and put it back in ? or is there an upgrade ? or possibly putting twin Mikuni's a better option ?
The steering cable is frozen, is there a technique for unfreezing or just purchase another ?
All your expertise and help is greatly appreciated, thank you
