Landen Koch
So I have a 2000 seadoo xp that the motor is getting overhauled on, and I pulled the fuel tank and all the motor mounts out and cleaned everything. I got an alignment tool for when I get the motor back and when I put it through, the shaft isn’t centered in the thru hull fitting. The fuel tank is back in and when I put the shaft up to the front of the tank, it is also very low, not even close to centered in that hole. Any ideas on how I could get it centered in the thru hull fitting?
