Hello guys!
Been a while since I posted on here.
Just bought a pair of 1999 gtx rfi skis with around 70 hours each. bodies are perfect no fading in the paint and no tears in the seat. I have noticed a few things wrong with them that I want to fix as I am a maintainer perfectionist and want these skis to be perfect looking and running even after 900 hours.
First off one of the skis needs a new info panel and the other needs a speedo. I found these on ebay and will fix soon. I know to use lots of dielectric grease on connectors to keep water out.
second they need covers. does poppy company make a good trailerable cover? if not who would you recommend?
I will also be replacing the trailer bearings soon.
third both skis make a decent amount of pump rattle. I read this is normal on older skis but also read that its fixable. should I bother to do this? if not what pump maintance should be done? these were driven in salt water for some of their life and will be used in salt by me a lot. should I get a new wear ring?
fourth what yearly maintiance should I be doing on these? I know 2 strokes need spark plugs every year and new gas and oil line filters. what do the pumps need? I understand there are grease fittings on the engine and pump but I don't know where and don't know how often they need replaced/packed.
lastly what replacements should I put of this from its original factory state. for example were these known to have issues with oil injectors blowing out and tying up the engine and therefor I should buy a blanking plate and pre mix oil and gas? do I need to replace the factory injectors because they get gummed up and stop properly functioning?
I know you guys are the best online for sea doo advice and would appreciate anything you can do to help me! thanks!
