1998 seadoo xpl 951 jetting
julius gomez
I have a 1998 seadoo xpl 951 that i need to rejet i have a r&d flame arrester,R&D intake grate and ride plate,Tdr baffled water box, and solas 15/20 impeller and the engine is .25 over what jets and carb setting do you recommend im in Indiana about 700ft over sea level.
Pop off should be about 20ish. If the accel pump gives a good squirt through the brass fittings on both carbs it should be fine.
