Jetskisareforidiots
Hello Gentleman, A new purchase for me its only showing 104hrs and is in really good condition. Guy I bought from couldn't get to turn over, but it was caused by the hydrolocked engine due to oil into the cylinders, after much oil in face, driveway, 30 rags later she fired up although that is not the issue. It is giving me an overheat issue, seems like .5miles is about how long it takes, it still runs the same except at idle when it idles up for 30-60 seconds then idles back down and I can go again. Apparently, it was used most of its time in a S.C. lake and looks so good I believe it. I know the check valve is leaking oil into the engine, not a priority atm.
I am a 2 stroke boat guy so this is new to me, I blew out most of the lines both directions, also to note of course it wont overheat on hose and is very cold coming out pisser. I took temp gun with me on last attempt after the air flushing and noticed it was very warm coming out of the pisser after alarm goes off, I got 115-120 degrees in my hand basically as hot as I want water in my hand before it really burns, for me that is a high temp on a outboard as its usually just very warm.
I can idle and within 10-30 secoinds the light goes away and I am good for another half mile at various speeds. At this point I dont think its the temp sensor but am not sure how to test with a OHM meter to confirm. I didnt blow out the exhaust/water box. Also, I am getting a decent/weak stream at idle. Could someone please tell me what temp I should be looking for on ski or where to go next. Should I pull the pump and check the inlets for debris as I cant see in them of feel for air when backflushing. I have read about the wear ring does this sound like it could be the issue? I have searched many, many posts I cannot find this exact issue anywhere.
The only temp sensor I can find is on the head, is there another to help me narrow down where its too hot or can anyone let me know how hot the exhaust/water box should be. I appreciate any wisdom or suggestions.
Thank you.
Thank you.
