Well.. what Ive been doing lately..
I have been riding almost every day/chance that I have been getting and its been running amazing!!!
What I did was write up a spring button so to the starter solenoid to activate it..
I would press that button with my knee when I push the button on the handle bars with my hand. Starts right up..
So, I think there is an issue with a frozen relay or broken relay in the MPEM causing the start button power source to drop out......
Anyway, new issue - I wanted to flush it out, and the key no longer detects on the ski - I just replaced a segment of wire to the DESS post which was corroded, and still no luck...
The beeper also does not work, or works rarely so I cant pull codes...
Any ideas?
EDIT: Got it to beep...
1 short, 1 long.. looking it up in manual... = diagnostic mode
Sometimes when key is in, and I hit start button I get 2 short beeps - then I try to press button again its 1 long one...
2 short beeps after diagnostic mode =
MPEM can not read the digital code of the safety lanyard cap or the magnet is defective.
So since magnet might be defective, I will use an earth magnet to remagnetize
Mixed wires at the safety lanyard switch (cant be possible, I replaced 1 wire at a time...)
