I have had my 1997 Seadoo Speedster (it has two 787 motors) for almost 2 years and have tried my best to keep up with maintaining it. I use it for wakeboarding and tubing and put it away in my garage where it sat for probably 3 to 4 months without use. My Seadoo starts right up but I don’t here any beeps. I have only heard the boat beep like for a few months on and off. My gauges worked in the begging but have died one by one and now not one of them work yet the boat starts up. The RPM gauges don’t work, while one stays completely below one and the other below one but not as far down as the other. I just recently took the boat out for a spin and started the motors up in the water just fine. I was just about ready to take off and the motors would deliver more power and begin to shake more than there suppose to, almost like something was stuck in the impellers. So i shut the motors off and put the boat back on the trailers and removed some weeds. I placed it back in the water and it repeated the same thing but this time the impellers were free of any debris. I once ran low on 2 cycle oil in which the motors began to do what they are doing now. I don’t think I harmed the engines when I did that because the boat has run pretty good since then because that was like a year ago. What I did notice though was that there is an excessive amount of 2cycle oil in the bottom of the hull. So what I’m wondering is if my oil mixture is causing my engines not to increase speed and create a violent shake. I tried to find where the leak was coming from and all that I found was most of the oil spillage is coming from the hose that’s located on the bottom. It’s the biggest hose not connected to the block or the carb but the other one. If anyone can help me with any and all my problems with my boat I would greatly appreciate it. I like this boat very much and I’m very handy, considering I have replaced one carb and built the other, as well as replace a throttle cable and shifting cable which was not fun, I have a little knowledge but not enough. Thanks For any help Mike.
