MendonMafia
Hi All,
I just bought a non running 1997 gtx and am getting close to firing this thing up. Its been sitting for 4 years in the Florida sun. Anything I need to do to increase my success?
Quickly tested compression dry, 100 psi each cylinder. Plugs actually looked good but i have new ones ready if needed.
i removed the carbs, cleaned, painted, and rebuilt them. I was sure to use the old springs and levers so hopefully my pop off is good. Anyway I can test pop off without specialized tools?
Getting new fuel line tomorrow.
Drained as much gas as I could with my siphon. I cant get the oil to siphon for some reason. Oil tank is nearly full but my siphon won't make it low enough in the oil tank. Is there an oil tank drain?
Should I pour some 10w30 into the case through the carb ports and some around the pistons through the spark plug hole?
How much carb tuning should I expect? I was considering thread and gasket sealer to mount the carbs but if im going to be removing the carbs every 10 minutes to tune them I will skip that.
As of now (haven't tried starting yet) the only issue I'm having besides a ton of corrosion that mostly looks superficial (but is quite extensive), is with my reverse gate. The cable has some type of housing/seal that keeps popping out when I push it into reverse and then it gets stuck on the hull when I try to go back to forward and the gate won't lock up. Even after I realign the piece so it goes into the hull and the gate locks up, the handle wont stay pushed all the way forward. Its like something is bent and pulls the handle back a bit when you stop pushing on it.
What else should I check and fix before I try to start this thing?
