1997 GTX pisser relocate
Hello all.
I hate the location of the OE pisser on the 97 GTX. I'd like to have it come out above the rub rail on the right side.
I see there was a DR. Honda part or something of the sort back in the day. Is there another part available that has the same hose diameter hook up? I saw in an old post to use a 2000 GTX pisser fitting. But i'm not seeing it in the parts fiche.
Never found any for quarter inch hose. Used to make mine own out of brass hose barb fittings
Probably not a problem with the flow. I would think the water will slobber out of a 3/8 hole. If you stick with the quarter inch you will have a stream.
