seadoo1997gtx
Got this 1997 GTX running like a champion on the 4th weekend, run out of gas, refilled and since then only problems.
It was partially running while on the ware but without power, got home and
Currently, it will click the solenoid once (with each start push) but will not start. (sometimes when hit the start many time quick it will make a 1 second starting attempt and quit)
I charged the battery (and replaced with a new one as well), I replaced the solenoid (with new one) twice. I pulled the starter out, cleaned and tested(it is working great outside). while doing the above , I cleaned the carb,& replaced the spark plugs.
When jump between the solenoid connections nothing happen (no sound, no starter.
I try jump strait to the starter from an outside battery yet the starter will not do a thing (was working outside when tested).
I cleaned, checked & secure all wires & connections (grounds and positive.)
ANY OTHER IDEAS???
ANY OTHER IDEAS???
